1990 135 Black Max S/N# OC138477<br /><br />Have a fairly simple question, or so I think. What is the resistance values I should read at the back of the trim gauge? I ask as I just installed a new sender. When tested by itself I get readings from about 40ohms up to about 90ohms. When I install it on the motor, using the recommended ground, I get nothing. If I take the ground off, and extend it to a ground point on the engine, I get the same values as stated above. Any ideas? I would expect to get about the same readings at the sender as I do behind the trim gauge--but that's not the case.
