I just woke my boat up from her winter nap and took her for a quick ride around the lake to make sure everything works ok. Although it started up easy and performed well, I noticed two guages were not working properly.
The tilt and trim on the OB motor (F150) works perfrectly well. However the guage only reads 1/2 trim when it is fully down. I tried cycling it a few times through the trim and tilt figuring something was stuck but it doesn't want to move lower than 1/2 trim when fully down.
Similarly the RPM guage is stuck at around 5000 RPS and doesn't want to move regardless of idling or WOT.
Other guages (speed, voltage, & fuel) seem to be working fine. The guages are manufactured by Faria which came new with the boat (5 yrs old) Is there something I may be overlooking or should I be planning to purchase new guages?
Helpful advice appreciated.
