The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
Is it possible for both the up and down relays to go at the same time. If the relay voltages are to low would this be a cause. Engine is a 115 Evinrude '95.<br /><br />Thanks
If the relay voltages are low then you probably have a corroded connection or a bad wire. I've seen several OMC's around the era of your motor with wires that go bad.
