Need to check the relay on my trim/tilt. Engine (1995 Evinrude 115), will not trim up. <br /><br />I hear cliking noises coming from the relay box when the up switch is depressed.<br /><br />Are the relays the two little boxes that sit side by side. Is it as simple as detaching the wiring and replacing?<br /><br />Any other thoughts to what the problem might be.<br /><br />Thanks
