Trim limit has continuity so that shouldn't be the issue.
The pump did have two solenoids at one point (it was drilled into the left side and held on with a bolt. I've tried testing both by applying power and seeing if allows the current to flow through to the other lug, no luck.
I suppose I'll pick up a new solenoid and see if that works. If not I geuss a new pump? Also applying power driectly to the motor wires does nothing. I'm thinking maybe it got fried when those wires crossed but honestly have no idea at this point.
