Trim Pump Help
brsox88
I have an issue with the trim pump on my boat (186 MONTEREY with 3.0l merc alpha II)
It goes down just fine, but if I try raise the transom it just makes a click noise coming from the trim pump. Why will it go down fine but not up?
Re: Trim Pump Help
Ayuh,... Jumper across the bigger lugs with a stout wire, on the thingy that's clicking...
If the trim motor runs, the solenoid is bad...
If it Don't,.. You may need a new pump...
The links posted by Don explains it in-depth...Along with Alotta other neat stuff...
brsox88
Re: Trim Pump Help
Ok where can I buy a new solenoid? Are they all the same for mercs?
