Trim Problem
Hi everyone , I am new to iboats and boating in general. I have a trim that is POURING out oil I believe it is between the main (ram) and where it is connected to the the tank and motor on bottom . In the pictures it appears to be leaking from the right side . I would guess that there is some type of O Ring that goes between the main ram and the cylinder at bottom ???? I removed 1 Pin like thing ( Framing Nail) at the top of ram to disconnect it then knocked out a much larger pin that goes all the way through .
, and then another pin ( nail) on the lower left . My problem now is I cant not knock the main rams larger pin through . I do see some type of set ( Hex) screws only on the right side . The left side is smooth Anyone know how to remove this . Thanks for any help.
I will post pictures as soon as I can figure out how to .
