Hi I just changed my trim motor on a 86 125 hp Force, when I went to fill the unit with oil not sure what has happened? Put some fluid in, stopped hit the switch to raise and lower it finally started to work, guess there was air in lines. I stopped and put some fluid in to top off, and was raising motor up and down, when I notice fluid coming out of the back of the pump . My base at the pump has 4 lines and in the center there a piston, or rod?? some thing that held in by a c clip, it appears that where it is coming out from , but just on the other side?
My question is it possible that I have fillled to full, thus making leak out there, and did it do any damage? The unit fill hole is on the side of unit which I could not tell if was full and just running out or just coming out from me putting it in? It has leak some out to form a good spot on ground, motor is still working, raising and lowering, just wanted some ideals, Thanks
