Mercruiser 4.3 LXH gen+. Trim motor for the stern drive won't run. The solenoid clicks when start button is depressed. Battery measures 12.5V. I measure 11.5V on the downstream side of the solenoid supplying the motor. I removed the motor and connected directly to the battery, and it runs. Is the 11.5 volts not enough to run the motor? Where might the voltage loss be? Is there another potential cause I am missing? Thanks.
