Re: trim motor breaker tripping...
In my experience a shorted switch just makes the motor run continuously, other words, the drive won't stay down. if that happened and the motor didn't shut off when the drive reached the limit of its travel, it'd probably trip the breaker.
for a switch to trip a breaker, it'd have to connect the 12V feed to ground, which I guess it could do if you have a DPDT switch operating the trim motor directly, but the motor is more likely driven by relays. I could be wrong about that, though.
