Trim limit switch
Johnnyroy
Hey guys!. Seems like my boat had a omc out drive but was swapped over to a alpha one gen two out drive. My trim limit is not working.
So I'm guessing there is no place to plug in the trim limit wire, assuming that because it's not plugged in,and I heard cobra drives had none
Is there a way to fix this. Also I cleaned both switches and checked the wires
Thanks!!!!
Ayuh,..... Welcome Aboard,...... It shouldn't matter, but We donno how much OMC was used, or not,....
Scott06
Thanks!!!!
Trim limit switch plugs into the trim pump harness at the pump. Trim indicator sender plugs into engine harness to get sent up to the helm
this is for a complete merc setup. Was the entire omc set up torn out or do you have some mix and match
