1989 5.7 Mercruiser Alpha One<br />My up trim is not working, solenoid not clicking. The down trim works and the "trailer" trim works up and down. I have no continuity between trim limit switch leads from where they leave the trim motor. There are two trim limit switches on my outdrive, left and right. The wires leading to the left one are bare and one is even broken. Obviously, that seems to be my problem. My Clymer shop manual only mentions ONE limit switch and gives no instructions as to how to replace it. Again, mine has two???? Now the big question....what is the procedure to replace it..them?? I assume that the whole outdrive must come off to replace them since the wires must be replaced too. DESPERATE! Please help. Thanks for this forum, as the manual sure isn't much help.
