trim issues on a 1979 85hp evinrude
knight_time
First off hello ive got a real quick question ive got a 79 85hp evinrude that i cant get to trim up. If i push down on the trim control it works fine ,but if i try to bring it back up nothing happens. A friend suggested replacing the relay does that sound like the best place to start replacing stuff ,or should i try something else. Also if anyone has a wiring diagram that would be a huge help also
Thanks
tashasdaddy
Re: trim issues on a 1979 85hp evinrude
swap the relays. then if it goes up you know you have one bad relay.
ezeke
You don't have relays on the 1979 motor; you have a single solenoid used only for raising the motor.
Check the solenoid wiring.
This diagram does not show the gauge wiring; let me know [PM] if you need it.
knight_time
thanks, i can only find one solenoid on the motor and it was replaced very recently
knight_time
off topic but i also have i believe its a 96 force 40hp that keeps blowing out (exhaust seal gasket?) ill take it to the shop get it fixed it'll run one trip without any problems, but the next time i take it out ill end up having to limb home with the cowling off the motor because the exhuast fumes build up inside the cowling and rob the engine of air. This has happened to me 5 times now and it always the same thing
kenmyfam
Post this in the correct section for best results.
knight_time
yeah i know i should've put it in another section i just didnt want to have abunch of please help me threads lol
kenmyfam
Put in the Force section if it is a Force motor.
ezeke
The PT&T solenoid for the 1979 V4 motors was not on the motor; it was in a black box mounted near the motor. The black box is denoted by the rectangular shape on the wiring diagram.
BTW, I was not suggesting that you check the solenoid when I said to check the wiring.
knight_time
Yeah i understood what you were saying about checking the wires i was just trying to figure out if there another solenoid that i wasnt seeing thanks for the help
ezeke
The diagram is directly from the 1979 factory manual for your engine. If you have anything else, it is not stock and you will have to post some pictures. The 1979 trim motor has three wires, not two.
knight_time
alright ive got tomorrow off so im going mess with it then hope i dont run into any problems
emdsapmgr
Ezeke is correct. On my 79 models, the factory glued a wiring diagram to the inside of the remote trim box cover. There is a separate fuse in the box for the trim. Make sure all connections at the box are clean and tight. The trim switch at the control box should have a plug-in connection hanging just below the control box. You should be able to disconnect the trim switch there and test the ends of the pigtail that run to the box.
merlin65
same thing happened to me last week. trim worked fine going down but when I tried to go up, no sound or anything. no clicking solonoids either. Removed the switch out of the gas lever at the remote. Cut the wires goint to the old switch and jumped the blue and green wires to the hot and it worked like a charm. I think blue wire is up and green wire is down. My switch was original to a 1988 boat so it was time for it to go out... My point::::: try the switch.
knight_time
is this the solenoid im looking for?
knight_time
that was my first thought that the switch is bad how did you get that switch out of there
emdsapmgr
Yes, that is the trim box. The small bulge in the red wire is the fuse. If the trim goes down OK, the fuse is probably OK. The solenoid is wired to control the "up" only-as that is the movement where all the current draw is. It should click when you depress the switch up. If it doesn't probably a bad solenoid.
ezeke
Looks like original wiring needs a little cleaning too.
If the PT&T works in either direction the fuse is not blown.
