At the moment I can not trim the outdrive from the throttle control. The trailering button works fine. I thought I had a solenoid issue so I replaced both, but I jumped to that conclusion obviosly since the issue is the same.
I have been reading how the limit switches could be the culprit and did notice under the dash that the trim indicator guage has one disconnected wire. So I'm wondering if the trim indicator guage is fed from the limit switches and does this break continuity to the limit switches and if so could that be the cause?
Sorry for the novice question up until pruchasing this boat last month I have only used them. I'm now learning to work on them.
