Trim..... How to use?
theservicegroup777
89 Bayliner. 2.3 I/O cobra outdrive. The trim is pretty self explainatory but I have to ask. When we open her up at WOT the planes out and rides perfect. I really dont feel a need to trim up? Just curious is someone could explain when to use it and does it have a limit that it should go up when running? We started wakeboarding and i was thinking of trimming up just a bit to get a bigger wake... didnt know if this would hurt it?
Re: Trim..... How to use?
alot of boats require trim down to stop the wheelies while getting on plane then once on plane the front will be bow steering so you trim up to loosen the front and as you get to the point where the prop is parrellel with the water surface it becomes more efficent and you gain speed with out adding throttle (some times its a fine line between max efficency and porpusing). on outboards the trim rams push the motor up but the tilt ram is to week to lift the motor against the force applied by the motor so you can not over trim the motor im not sure on inboards
scott8058
Whenever we take off in our inboard we trim all the way down as it gets on plane much faster and not much bow rise. If i leave the trim all the way down once on plane it drives fine but feels very inefficient and like there is a ton of drag. When im on plane i look over the side to see where the spray is coming off the boat, i trim up until its near the back of the boat. If we trim to far it starts bouncing up and down (porpusing i guess its called) but either way you should feel the boat gliding easier thru the water. Good luck
HT32BSX115
This is pretty much exactly how you want to do it.
You cannot really go by the gage because the drive position is really dependent on speed and load (passenger position etc)
You do it by "feel". If you trim too far bow-Down, you'll feel that "drag" that seems like you're "plowing" with the bow.
If you trim too far drive-out (bow-up) you'll get porpoising and a rough ride. It's different for every boat and load (in the boat)
Ideally, for efficiency, you want to trim the boat for maximum speed at minimum fuel flow (which = minimum drag) It's like an airplane.
If you have a fuel flow gage, you can do it pretty easily. If not, you can learn experimentally to trim for maximum speed at the most "comfortable" cruising speed and power setting.
The trim setting will not "feel right" if it's too high or low and you'll notice other clues like bow height, engine sound, porpoise, vibration, etc. Just moving someone from the back seat to the front seat will change it......
Operate the trim switch with your thumb short "bursts"......that's why they usually put it on the throttle control....
Cheers,
Rick
