Re: trim getting up on pad
If I understand correctly, you are saying that when you are up on plane and running, When you activate the up trim you don't see anything happening.
Also, as I understand you, while running the engine, it will not tilt up yet it does when the engine is not running.
First, the trim and tilt are separate functions; the trim is the center cylinder with the pentagon shaped cap and the tilt is the hydraulic cylinder right next to the starboard clamp. The other cylinder has no lines and is just a shock absorber. Even though the trim and tilt cylinders are fed from the same valve, because of the greater hydraulic advantage, the trim cylinder will move out first. Then when it reaches the limit of its travel, the tilt cylinder will move. Tilting DOWN, it is just the opposite.
Second: On some engines even though there is a much higher mechanical (hydraulic) advantage to the trim cylinder they still function slowly. Note that because of the much greater advantage of the trim, it will always function much slower than the tilt cylinder. Because of this slowness, it may seem as if the engine is not moving when you activate the switch. The trim cylinder only has about a two inch travel and if you are not paying attention, you may not notice the different engine position.
Third: because of the much lower hydraulic advantage of the tilt cylinder, it will never tilt while you are running the boat at almost any speed. It just is not strong enough. Additionally, there are relief valves in it. Once the trim cylinder has reached it full travel, at any speed much over 3-5 MPH, the tilt cylinder will not work no matter how long you hold the switch on. More next.
Fourth: You can never operate the tilt at anything much over 1000 engine RPM. It just will not rise. This number varies from unit to unit. Some good ones will operate at up around 1500 RPM. You can operate it at engine speeds around 1000 RPM but if you increase the engine speed again with it tilted, the relief valves will open and the engine will rapidly tilt down (or slam down) until it contacts the trim cylinder plunger.
