Trim Gauge
ambrose
Hello everyone just brought this boat and the Trim gauge works but when I put the trim all the way down and start driving the needle goes all the way up but when I'am going I start to put the trim up the needle goes back and shows the trim going up? It is a 2006 Larson senza with a 5.0 volvo penta? Any suggestions?
Thank-you.
insttech1
Re: Trim Gauge
The sending units are notorious for going bad.
You can do a search on here about trim or sending units or tilt and find a ton of posts on it.
They go for about $100 to 140 to replace.
Don S
Re: Trim Gauge
It sounds like a bad sender, you can test it and try readjusting it to see if it just not installed and adjusted properly.
Here are the instructions.
  • SX Trim Sender Replace.pdf
