Trim Gauge
Status
Not open for further replies.
karayj
does any one know what they call the 2 adjusters on both sides of my lower unit that tell at what angle you lower unit is at and what does the one on the right do compared to the one on the left the reason im asking is that me gauge works but as you tilt the unit it the gauge needle stays to the far right for awhile like its not working then it moves forward a little then back to the right then when the unit is real low it starts to work I just would like to see the gauge work all the way through the entire tilt process, is it the gauge on the dash ?? or is it the fact the the wires were broken before and that i took it part i put the one on the drivers side in correctly but the one on the passenger side i may have put in wrong but when i move the passenger side one back and forth the gauge does nothing so im assuming it does not matter its the driver side one that does all the reading any info would be great.......
Status
