JACKULLRICH
- Nov 22, 2002
- 21
I am almost there. The last part I am hooking up is my trim gauge. This is an Omc Part number 174679. What I have on the back of this unit is G=ground,I-ign,and S for sender. The question is there is some sort of resistor across the I and S. I am not sure if the purple wire is supposed to go on the Ign and sender wire on the S terminal with this somewhat resistor, in series. This is for a 1988 Johnson 110 vro engine. The trim plugs into the wire harness, No Problem, but I have two wires left over. One is a black wire with a round spade for a screw, and the other is a white wire with a gold or tan stripe. Thank you for any and all responses. Happy Holidays to all. Jack
