I have a 1982 Mark Twain 17.5 ft. ski boat with Mercruiser I/O drive, 228 HP. I have replaced the trim sender unit twice with new ones. The sending unit and gauge work perfect with key on, motor off, throughout the entire trim range. When engine is started, trim gauge needle rises and fluctuates with engine RPM. Seems like varying voltage from the alternator is causing gauge to vary. Anyone have any ideas? Thanks in advance.
