My trim gauge will register all or nothing. Full up or full down, but nothing in between. I followed the suggestions in some earlier posts to clean the contacts in the sending unit on a Mercruiser Alpha drive. I found that the sending unit has a considerable amount of grease/lubricant in it. Is this normal? If so, is there any special type grease to use after the contacts are cleaned? The grease has a green cast to it, so I suspect water has gotten into the unit. Thanks
