Re: Trim gage not reading correctly.
Hi Bozzman,
I am not sure what you have understood from my post, the trim sensor is the potentiometer that is mounted on the stern drive, there are only 2 components to the system, the trim gauge and the trim sensor (or pot). There is no trim sensor on the back of the gauge, but I was asking that you disconnect the wire that leads from the trim sensor to the trim gauge (the wire is connected on the back of the trim gauge). You can then connect the grounded lead to the connection on the back of the trim gauge and check if the needle on the gauge moves from fully up to fully down..
Not much goes bad on the outdrive, but the trim sensor (potentiometer) does go bad, water sometimes gets inside, the insulation on the wires goes soft from water immersion and starts to fall of letting the wires short out, etc
Its a PITA to change the senor and its wiring, you usually have to remove the outdrive although someone recently posted that they managed to do it with the outdrive in place (but I suspect it needed a real contortianist!! See if you can find the fault before you start worrying about changing the sensor.
I hope that made it clearer?
Regards Gary
