trim gage adjustment
mwelskopf
How do I adjust the trim gauge on my 1996 90 degree johnson 90 hp? When engine is at its lowest position, the gauge needle is way below the marks. Thanks
clanton
Re: trim gage adjustment
Tilt engine up as far as it will go. Look under engine pan between mounting brackets for trim sender, loosen 2 screws(lots of luck) move sender to move gage needle to position you like.
