Lookin for some advice. recently had my engine and outdrive pulled for some transom repair, and transom seal replacement. Took the boat out and it ran fine, until I noticed when I would trim down or back up it was not responding well. after about an hour on the water, it was not trimming at all. (Stuck trimmed all the way down). checked the bilge and it was full of hydraulic fluid.
Any ideas on what this could be? easy fix? hard fix? what part I might need? Im thinking trim line, but with it leaking internally is it possible something just needs to be adjusted or wasnt reconnected correctly after the transom seal was replaced and everything was put back together?
Thanks!
Thanks!
