Re: trim fault
I am thrilled to say that this problem is now fixed!
I called Mercruiser technical support again to go through the problem. After describing it again, the rep said that I should try readjusting the sending unit mechanism. He said that the ohm reading with the lower unit lowered should be around 17 ohms. When I checked mine, it was something in the neighborhood of 200 ohms... After I reset the switch and recalibrated the smart craft unit, all is well!
It should be known that I bought a repair manual for my engine/out drive model, and it really didn't help much at all! It didn't give ohm readings for lower/raised... Nonetheless, I am glad to have it as a reference...
This link is a good reference for the
procedure from mercstuff.com, but more detail is required for those of us with smart craft gauges with digital trim readouts.
After reading the instructions, I did the following.
CALIBRATE TRIM SENDING UNIT
1. Located the wires coming out of the out drive label trim sender (or something of that sort).
2. Disconnected them and connect an ohmmeter to the wires that go back to the switch (into the out drive).
3. Set the meter to ohms and read the ohms reading as I raised the out drive.
4. After confirming that the reading was working, I lowered the out drive and noted that the resistance (ohms) was at ~200ohms. The merc rep recommended that it be set to 17 ohms.
5. I loosened the switch and rotated it to get the reading to 17 ohms and retightened.
6. Connected the wires back together and turned the key on to let smart craft fire up.
7. I raised and lowered the trim and found that now instead of reading from 0.0-10.0 degrees (0.0 = lowered, 10.0 = raised but not trailering position), my gauge was reading 0.1 lowered to 11.0 raised. Doh! I needed to recalibrate the smart craft gauge...
CALIBRATE SMART CRAFT GAUGE
1. Refer to the
Smartcraft SC1000 Manual
2. Follow the calibration instructions on page 27 and 28.
3. That's it. Test the setup by raising and lowering the out drive. You should read 0.0 when lowered and 10.0 when raised.
Since I've done this, I not had a trim fault. I've been out on the lake ~5 time since making the change.
I hope that this write up helps and good luck!
