trim cylinders
finx
I took the 2 steel breaded hoses off of the trim cylinders. Should I be able to push in and pull out the trim cylinders by hand or are they frozen up? They wont twist or turn or do anything. This boat hasnt been run in 15 years and I'm trying to figure out what I need to get it running again. Thanks!
achris
More fish than mountain goat
Re: trim cylinders
The Gen II cylinders are sometimes a bit stiff, but previous models, especially MC-1 cylinders should be easily moved by hand... If it hasn't been moved for 15 years :facepalm: then I'd bet the end caps have corroded and need replacing....
Chris......
finx
Re: trim cylinders
You think the end caps are corroded? I did a quick search and the whole trim arm would cost me $500 for the pair. End caps about $50.00. I wouldnt have to replace the whole arm, Correct?
achris
Re: trim cylinders
Open them up and see... If they have been left without fluid in them, all bets are off...
fishrdan
Re: trim cylinders
You can buy SEI (china knock off) trim cylinders for $120 each.
finx
Re: trim cylinders
When I took the steel hose off no fluid came out. I'm sure their hasnt been fluid in there for years. lemme go take it apart.
Re: trim cylinders
Ayuh,.... Ya gotta Love those guys,.... They're bringin' boatin' back to Us poor folk,.... ;)
kwoolard
Re: trim cylinders
If you have a pre-alpha drive, send me a private message....I've got something you just may want.
Keith
finx
Re: trim cylinders
I soaked them in WD-40 and took some channel locks to them. Not budging. They are solid. In fact, so solid I might use them as jack stands on my next rebuild.
I give enough of my money to the Chinese through harbor freight tools. Lets see what the used market has.
picklenjim
Re: trim cylinders
Did you try extending them with the trim pump? Leave the aft anchor pin out and give it a shot. You would be surprised what 3000psi can do.
