I am attempting to remove the trim cylinders on my '85 merc MR 200. I am having trouble removing the 2nd line from under the bell housing. The nut is starting to strip. Am I missing anything or should I keep trying?
Penetrating Oil will Help,..........<br /><br />After you strip the flats off the nut,..... Switch to Vise-Grips.............<br /><br />BTW,........ You'll be Needing New Lines.........
