If it is leaking where the electric motor mounts, it is just an o-ring. Remove the three screws, pull the motor off and push aside, clean up oil mess, clean surfaces, spray surfaces with starter fluid, or ether to remove oil, etc. Coat new o-ring with Permatex Aviation Form-A-Gasket, install o-ring and re-mount electric motor. Coat screws with gasket goop too, makes it easier next time. If it is leaking from the main seal around the middle / main strut, give it up. Take it to a shop to have that seal replaced. It requires a spanner wrench OMC tool. OR I can explain the full proceedure to you......If it is leaking from a hydraulic fitting just try tightening it up a hair.
