I have a 1994 Johnson 40hp. The trim button on the side is worn out. Sometimes it will work if you hold it in for a while. Other times you can only hear the relay clicking under the motor housing. Also, the up button will stick, could this be the cause of my battery draining down. It seemed like when I giggled the relays it worked better.
