Trim and tilt compatibility
bulletsaltcreek
I have a 96 model 60hp Johnson. I'm ​having problems with my trim cylinders not coming back down, locked up. I've found a used unit that came off a 80's model Evinrude. It looks identical to mine. Is this compatible and if so, isn't a fairly easy swap? Bolt and unbolt and hook up power?
flyingscott
Put up a model #. A 96 3 cylinder I believe has a fastrac unit they came out in the early 90s. The earlier ones are different and slower.
