Re: Trigger
Thanks Jim, I am getting intermittent spark, I will be cranking the motor and there is no spark on any of the plugs, using a spark tester. Then 10 minutes later I have all spark back. I have a new stator installed, and have voltage readings within specs going into the switchbox as read from a DVA meter, but no spark so I am leaning towards the switchbox being bad. After the engine starts, it seems to continuously start whenever I turn the key, but when it sits for a few days the same symptom occurs, it wont start, but then after awhile of trying to get her running she pops just like that. I am reading 1200 ohms on each of the trigger wires to the bias wire(white/black) on the switchbox, I do have all the wires disconnected from the trigger on the switchbox when I did this ohm test. I am also getting the open reading I should from each trigger wire to engine ground.
