trigger test
spiritwild66
98 150 40amp sys, trigger test correctly per OEM specs, OEM dose'nt give info for this when moving throttle arm, should there be a change in the resistance during the travel, mine is reading exactly the same at both ends of travel there are changes in between?
Faztbullet
Re: trigger test
No... all your doing is measuring resistance of coils in trigger.
spiritwild66
Re: trigger test
Thanks, got a intermediate missfire comes in around 1500 rpm through WOT, appears I have a trigger prob.
schematic
Re: trigger test
don't discount the switch box.
The readings you were getting while moving trigger are due to voltages you are inducing from the movement. (normal)
spiritwild66
Re: trigger test
have sw/boxes on hand,, inner sw/box shows signs of arching reluctant to put them on until I am certain of the root cause.
schematic
Re: trigger test
you likely will never be sure of the root cause until you swap components. Intermittent double firing doesn't often show its ugly head with meter tests.
God hates a coward.....swap switch boxes.
spiritwild66
Re: trigger test
Thanks Faztbullet, the wires going to the inner sw/box are spiking up in the mid to high 1600's did see 1800 one, replacing the trigger.
