Hello all,
Last August I bought a "new to me" boat, but it was definitly not new.
It was a 1976 Invader Continental 18' boat with a inline 6, I believe 165 HP.
Anyways, when I got the boat, it came with 2 propellers (one on it and an extra). The one that was on it for most of the season last year was the smaller of the two.
Over time, I was hoping to increase speed so I tried out the larger propeller. I also noticed that I was maxing out the RPM on the gauge when at full throttle on the smaller propeller. After doing reading in my manual, I found out that the WOT should be at 4800 RPM. So, that further help indicate that I could go to the larger propeller.
The other propeller, was not that much larger and definitly had some more pitch. In my original calculations last year I thought it would bring down my WOT closer to the 4800 RPM.
Anyways, when I went to use it, occasionally when shifting into forward or reverse, it would make the engine stall. It was almost like the weight of this propeller or the size of it was enough to make the idle RPM cause a stall under the load.
It would not stall everytime, but it would definitly do it if the engine was not warm enough. And when it didn't stall, it would sound like it would until it got it spinning and it would be fine.
So, my question is, do I just need to adjust the idle RPM to be slightly higher? Should I just go back to the previous propeller (I did occasionally have this issue, but was MUCH more rare).
I am thinking I just need to increase the idle RPM a little bit, but not sure.
Thoughts?
Thoughts?
