eavega
- Apr 29, 2008
- 1,377
I have a 1973 25 HP Johnson (25R73A) that I am trying to dismantle for parts. I have a manual for a 1968 20 HP Johnson (my current motor), as well as the Seloc manual for Johnson outboards <40 HP. Its really not worth it to me to get a service manual for the 25 HP, as this motor is beyond reasonable abilities to get running again (The pistons are solid lumps of rust, carbon, etc).
I am trying to get the power head off of the exhaust housing, and I was able to identify and remove the 5 bolts holding the power head to the exhaust housing, but there is one that is tucked up under the power head, behind the tiller bracket, that I can't find a reasonable way to get to. In the 1968 service guide for the '68, it mentions that there is a "Phillips head screw" at about this location (which would make sense, as you could get a screwdriver up into this tight space). This, however is not a phillips head screw but rather a hex bolt. I can't get a socket or a wrench up in there to get this bolt off, and there is no guidance in the Seloc manual about removing the tiller handle first or anything of that nature.
I was wondering if anyone knew of a way to get to this bolt to take it off so I can lift off the power head.
Rgds
Eric
Rgds
Eric
