Re: Tri-Hull or Flat Bottom for shallow water
three feet isn't shallow! it won't make any difference what hull you use (assuming under 20') in three feet.
Of course you want an outboard, regardless of depth but especially if you will be going to real shallow water. And a stainless steel prop.
A sand/mud bottom gives you the safe margin of error and an oar or shove pole gets you out! Sometimes you just hop overboard and walk it out; if it's knee deep you drive. Oyster rocks can be a problem.
Look at the stern and the deadrise, and the depth from the bottom of the hull to the waterline, to get your minimum float depth. For my 19' Carolina skiff it's about 4". A 17' whaler would be about 6" (guessing) and when you get to other hulls, there's lots of variation. Of course when you add weight (people) it will change, too.
I can run slow with the motor kicked up with just a few inches below the hull. Putting people up front helps--it's a skill you just have to learn not to put too many and have the bow dig. With the motor up you lose some steering and control.
Power tilt is your best friend for shallow water use.
You can run on a plane over water too shallow to run at hull speed but you have to be on top of your game to do this, and have all passengers secure.
Rememer, too, it's dangerous to pull a skiier, etc. over shallow water even if the boat runs fine, due to spinal injury or oyster bed slicing if they fall.
I just came back from a week on a barrier island running several boats in skinny water. there's a lot involved in successful and safe shallow water boating.
