tread depth of tires
llfish
At what tread depth should tires be changed? I was on the road the other day and stooped at a Wal-Mart to have my oil changed and they told me that I needed two new tires. They said the depth was 5/32. Tires do not look all that bad and I normally would wait a little longer before buying new ones.<br /><br />Just wondering if they are unsafe or are they trying to sell tires?<br /><br />Thanks for the info.
Tyme2fish
Re: tread depth of tires
Wheel world: What you need to know about tire buying, maintenance and technological advances <br /><br />July 20, 2000<br /><br /><br />Tire experts say drivers shouldn't wait until their tires are bald before replacing them. Buying tires is a cinch with a few quick steps to determine when your old ones are worn.<br /><br /><br />Check the tire's tread depth first, said Al Prince, manager of Goodyear, 3075 E. Grand River in Detroit. Tread depth should be the determining factor for when new tires are needed, not mileage.<br /><br /><br />Some use the penny test to check tread depth. Stick a penny into the tire groove. Make sure that Abe Lincoln is right side up. If Abe's head is visible, there's not enough tread on the tires. According to tire experts this is not safe and is illegal because the minimum legal tread depth is 2/32 inch. But Prince said he doesn't like to use the penny test because gauges are more accurate. <br /><br /><br />"Brand new tires are about 10/32 of an inch," Prince said. "A tire that is 4/32 of an inch needs to be changed because it's 80-percent worn." <br /><br /><br />Looking at the customer's vehicle is important for a few reasons, Prince said. The tires show some telltale signs that indicate other problems.<br /><br /><br />If the tire tread is more worn in the middle than on the edges, the tire is overinflated. If the tire treads in the middle are less worn than on the edge, there's not enough air in the tires. Tread depth gauges can determine this, Prince said.<br /><br /><br />Proper wheel alignment is another maintenance problem a tire's treading can reveal, he said. "If tire tread is deeper on one side more than the other, the wheels aren't in proper alignment."<br /><br />Hey, I've "stooped" and gone to Wal-Mart too. :p
one more cast
If you look in the groves of the tire you will find a raised portion (wear bar) when the tread is wore down to these bars it is past the time to replace the tires. I always replace mine even before they wear that far.<br /> NOTE: the wear bars are 2/32 of an inch high and in most states 3/32" is min. legal tread depth.
craze1cars
Originally posted by One More Cast:<br /> the wear bars are 2/32 of an inch high and in most states 3/32" is min. legal tread depth.
This is true. Also be aware that tires lose a large portion of their wet and snow traction only at about half-life. So that 5/32 guideline isn't necessarily a bad idea if you drive in bad weather regularly. That's about as low as I ever let mine go. And with winter approaching....it's probably a good time.<br /><br />Then again, I see you're in TN, not sure how much snow/rain you get there. If I lived in a dryer climate, I'd probably let mine go down a bit further.
Ayuh,.........<br /><br />3/32" is the Legal Limit in Ny..........<br /><br />I replace all 4 tires,.. Every other Year on My pickup...........They're Probably down to about 5/32" Now,.......<br />Must be This Year is My Tire Year,........ :D
llfish
Well it rained to day so I had to go out and check for handling problems. Found none. Checked a couple of old tires that I have keep for the trailer and they were 3/32 and 2/32. So maybe my previous judgment was not to bad.<br /><br />Thanks for the help!!
