transplanting guages and how they are wired?
thebrain
Banned
I'm planning to restore a older boat probably a 1982-87 boat and salvage a engine and guages from a
late model boat and transplant this guage among other guages
this appears to be a multi function guage, seams like the remaining guage will
only be a tach.if not what would be the remaining guages?
how is this guage connected?
I'm assumming it's connected to a fuel tank sender. is this a Yamaha sender?
or can a universal sender be adjusted to work because I may not reuse the
Yamaha fuel tank?
doe's the speed reading have a transducer that's in the water?if yes can it be wired over the transome
into the water?
doe's the Battery also have a sender?
I'm thinking the trip is just basically a stopwatch, and the time is hard wired to engine for hours?
Thanks STB
Silvertip
Honorary Supreme Mariner
Re: transplanting guages and how they are wired?
Go to the very top of this Electrical forum (not this page) and look at the "Generic Boat Wiring Diagram". It shows you how gauges are wired. It doesn't matter if you have separate gauges or if they are incorporated into one multi-function unit. What may be issues are the engine-specific senders -- specifically the temperature, oil injection, and trim senders. The tach (separate instrument in your case) reads the number of pulses from the charging system on the engine -- not the ignition system. The tach has an "S" (sender terminal that the tach signal connects to. Like all other gauges, it also has a +12 volt, ground and another terminal for the internal light ("L"). That terminal get wired to the NAV/ANC switch (NAv position since you don't need instrument lights on when you are anchored). The fuel sender is not engine specific so it connects to the FUEL "S" terminal. Temp gets connected to the TEMP "S" terminal, etc. The VOLTMETER does not need a sender since it is measuring system voltage. +12 volts and ground with the key on is all it needs. The speedometer is not an electrical gauge. I has a plastic tube that runs to the pitot at the back of the boat or to the pitot built into most outboards. As the boat moves water pressure compresses air in the tube which makes the speedo needle move. Think of it as a round tire pressure gauge.
