Outboard guy
- Mar 14, 2009
- 4
This sight has been so helpful until I got to this topic. Going through some of the old threads made me feel crazy. I have a 1996 aluminum Ranger Cherokee and want to add another transducer on the other side of the hull and don't want to drill holes if possible. The old threads suggested using a mounting plate. Sounded good until I kept hearing nothing sticks to them. Then some one said the plate comes with hardware which would suggest even more drilling than direct application. Unless they are referring to hardware to fasten the transducer to the plate which really would have nothing to do with the topic. Another person said you have to go all the way through on aluminum and bolt it on which sounds insane to me. One person said silicone the plate to the hull. This sounds good but will it hold?. I don't want to use epoxy so strong it would cause more of a mess than a few sheet metal screws. Which brings me to my final point. The original owner or dealer just screwed the Lowrance skimmer right to the Hull. Should I be worried about the core mat?riel getting rotted out ?
