Re: transom support
Transom savers transfer shock to the trailer frame rather than the transom. However, I've seen and read where lower unit housings have been damaged by severe shock loads imposed on the housing. One must, however, know all of the circumstances before passing judgement on whether the transom saver was at fault, if it was installed improperly, or if not used at all, would transom damage have occured as the result of the shock. I use one.
