CaptainPuget
- Sep 29, 2002
- 137
I have a 1970 vintage 18' aluminum boat that has the beginnings of rot in the transom. The transom construction is 1.75" of marine plywood inside, .100" of 5053 aluminum outside. The splash well is aluminum and is attached to the plywood with SS woodscrews. Several of these screws on the starboard side have pulled out of the wood and created a gap between the transom and the splash well. Water has run down the inside of the transom and there is some rot starting there.<br /><br />I've dried out the wood and reattached the splash well to the transom by drilling all the way through and replacing the wood screws with SS bolts & lock nuts. I sealed the bolts and the splash well/transom interface with 3M 5200. <br /><br />I've had two products recommended to me to stop the rot and restore the strength to the plywood. The first is Clear Penetrating Epoxy Sealer (CPES), the other is product called Gluvit. Does anyone have any experience with either of these products or can recommend something else for treating the plywood. I have no experience with repairing wood rot and I'd appreciate any comments from those that do.
