Transom Mount Transducer
Reel Poor
Will a transom mount transducer shoot through the hull if installed like a shoot through transducer? :eek:
mattttt25
Re: Transom Mount Transducer
i'm pretty sure the answer is no, but will let others jump in.
D
DJ
Guest
Sometimes. Contact the manufacturer to be sure.<br /><br />Most offer a different "puck" for in hull installations.
Moody Blue
Many will work this way but you need to expect a certain performance (sensitivity) loss as the ultrasound is now partially absorbed in the hull during transmit and again on receive. Several of the mfrs that I have seen show both methods of mounting the transducer in the installation instructions. Whichever type transducer is used, you must be very careful not to get ANY bubbles in the epoxy potting compound between the tranducer and hull.
Reel Poor
First of all, thanks for the replies.<br /><br />The reason for the question is im looking at a Hummingbird Matrix 97 in a kit which includes a GPS antenna and a transom mount transducer. I wanted a puck but they wont substitute parts. I do not want to mount the transducer on the tramsom<br />and thought this might be an option.
