fullsize_chevy
- Jan 16, 2005
- 31
The Lowrance M68C says you can mount the transducer inside the hull using 2-part epoxy. My boat is all fiberglass...no wood or foam. I intend to epoxy the transducer to the inside of the hull near the transom on a flat spot. Does anyone have any advice or special precautions I should be expecially careful of? Are there downsides to doing this vice the traditional transom mount? The transducer also comes with brackets for mounting externally on the transom. Thanks in advance.
