ChrisSchumacher
- Mar 12, 2014
- 10
I am posting here because I would like to follow. Same problem. Changed bellows, No leaks there. Filled bilge with water (inside engine compartment), slight leak outside, bottom of outdrive between the transom plate and the hull. 3M 5200 tonight. Will tell progress in about a week. Cure time for 5200. By the way, shifting cable and sleeve are good. Boat is a 1986 4.3L Four Winns. Fresh Water.
