mad:I recently boat a 17' Gregor aluminum skiff the question I have is the transom is 22" and I mounted a 1990 2 stroke 40 hp yamaha with a 20" shaft. When I plane I can visibly see the anti-cavation plate I been told by friends the outboard is to high and i should lower it. The question is theres two fins a small one 2" above the anti cavation plate which should be even with bottom of the hull. I do get some cavation when turning hard and on plane or when backing. I can also almost see the prop when planed out. Any help would be great and thanks for a great boating site.
Izzy650
Izzy650
