Just finished the steering / swivel pin on my B3 transom assy. Was not as difficult as anticipated, just a little time consuming, taking it nice and slow. Coming apart was far more difficult / time consuming than re-assy.
From what I understand (don't quote me) the Alpha Gen2 and bravo's use the same transom assy and gimbal ring, but the the major differance is Alpha Gen 2 bell housing is set up for shifter linkage for Alpha drive unit and the Bravo only has the cable in it, as the shifter is internal to the Bravo outdrive. The new assys are beefier than the old Alpha transom assy's / gimbal rings / bell housings
Gimbal housing for both alpha gen 2 and bravo have different part numbers, gimbal ring as well. Obviously complete transom assemblies (gimbal housing, gimbal ring, bellhousing all assembled ) are also diff part numbers.
gimbal housing part no alpha gen 2 8M0062568
gimbal housing bravo 8M0096216 , 8M0096217 for seacore
gimbal ring alpha gen 2 865328A01
gimbal ring bravo 8M0062440, 8M0063519 for sea core
Major parts interchange seems limited to gimbal bearing itself, the gimbal to transom seal ( same part number but show different shapes on parts dwgs so shape of gimbal hsg is different). Merc uses diff part numbers for upper gimbal pin, but aftermarket stainless upper gimbal pins show alpha and bravo both use the same. Steering arm looks the same too.
