1976_SkiTique
- Apr 27, 2003
- 20
This might get kind of long so I apologize and please bear with me. <br /><br />I think I have transmission problems in my boat, a 1976 SkiTique. It is an inboard with a 351 Ford, and a Borg-Warner 71C velvet drive with a 1:1 ratio The symptoms included; When starting to get somebody out of the water, if you punched it, it felt like the prop wasn't catching, if you eased off on her you could get it to go. It gradually got worse until you couldn't even pull anybody and it had trouble even going. I was able to dirve it out of the lake at slow speeds to put it on the trailer for the winter. Before this(I think) I had to jack up the motor to gain access to replace a freeze plug. I don't think I did, but it is possible I may have bent the shaft. Do the symptoms sound like transmission problems, or possibly a bent shaft? How much work is it to repair the transmission? I'm fairly mechanical and the marine transmission seems simple enough.<br />Thanks,<br />Jeff
