Transmission having trouble engaging in forward gear
Kerrs_Light
Boat is a 2000 Cobalt 246
Volvo Penta 7.4 Gi fuel injected DP I/O....appx 450hrs
Hey guys...this is my first post here, so bear with me.
Recently I noticed the transmission struggling to engage into forward gear. The throttle will click into drive, but does not engage. If I get on the throttle a bit it will engage. Occasionally once I click the throttle into drive it will engage after a few seconds without raising rpms. It seems that if I have been driving in forward, shift into neutral, then back to forward it engages fine. It's when I go from reverse to forward that I have problems with. I haven't noticed any problems when shifting into reverse.
From the little bit of reading I've done, it looks like it narrows down to the bell housing. Is this correct? If so where do I go from here?
Any help is appreciated...thanks guys.
Don S
Re: Transmission having trouble engaging in forward gear
Could be nothing more than the shift cable being out of adjustment. Remove the plastic cover on the back of the drive and remove the props. Now start the engine (on muffs) and shift into forward. Make sure the shift mechanism goes all the way into gear, both forward and reverse. If not, you may need a new cable.
Kerrs_Light
Thanks Don. Do you have/know where I could find some sort of manual to follow for this? If I end up having to replace the cable it always helps and saves time to have some sort of reference to follow.
Don S
There are manual links up in the Adults only sticky. But you won't find that information in it.
Kerrs_Light
I attached a video, which serves as a picture of my outdrive. I am to remove the cover with the VolvoPenta DP logo correct?
Don S
attachment.php
Note: The eccentric should be horizontal in neutral.
Kerrs_Light
Thank you sir...I'm going to dive into it when I get home.
