Backstory: Just got this motor running this week (90' 150HP). Had a problem that it would run on the muffs, but not in gear in the water. I had "rebuilt" the carbs (which are from a 1976 200HP Johnson) the week before, but missed an important step. I didn't remove and clean the jets. Took them all apart, removed the jets this time with the proper tool and cleaned them well, noticing many blockages in them. Took it to the lake yesterday and it ran great, however I did not idle around much.
Took it to the lake today and now I noticed this problem: After idling for long periods (over 45 seconds), or turning the motor off, it will die when trying to accelerate. If I try to go past about 1/4 throttle it will bog down and die, like it is starving for fuel. Bumping the choke does not help. It will start up again immediately after. The only solution I found was to run at 1/4 throttle for about 30 seconds, and then it would transition fine without dying after that. I can even go back to idle and back to high speed with no problem UNTIL I idle for a long period.
FYI: I am running directly from a new 6 gallon test tank with new fittings, primer bulb, and hoses when this occurs.
EDIT: It also doesn't help by squeezing the primer bulb, which I think would rule out my next comment.
I was thinking maybe fuel pump(s), but that doesn't explain why it runs well at full throttle sometimes. I am lost as to what to check next. Thanks for the help everyone!
-Hoop1101-
-Hoop1101-
