Re: Transducer mounting height??
my understanding is it should be a little below the hull, this way any air bubbles that may come off the back of the boat will not cause interferance with the reading you get. but if you mount it low, make sure if you hit something in the water like a stick or whatever, it will swing up and not break. In the end it's your choice...
