ggundersen3
- Dec 25, 2007
- 249
My 2006 Four Winns Horizon 180 was ordered from the factory without a depth finder/sounder. Faria and Humminbird both make several that will fit. There’s is the 2” cutout/space with the easily removed “blank” to mount the guage on the far left of the dash/instrument panel. 3 questions here: Is a through the hull or transom mount transducer better? What are pros and cons of each? If going with a transom mount type, should the transducer be mounted to some sort of block and the block mounted to the transom with some sort of waterproof/ underwater adhesive to avoid drilling in the fiberglass transom? Advice appreciated!
